Convert from .dxf to .pdf problem (solved)
Jim0000
Post by Jim0000 » Sat Oct 03, 2020 12:28 pm
I am experiencing problems converting a .dxf drawing to .pdf tonight.
When I do it, the result is just a blank document.
It formerly works fine.
What could I be doing wrong, can someone please advise?
Edit:
Problem solved, I had the incorrect scale chosen in print preview.
