When drawing an rectangle it ends up in four lines
MxV
Post by MxV » Wed Sep 23, 2020 3:50 pm
Hallo,
Before when I draw a rectangle it ends up in an poly-line and I could move it as one entity.
Now the rectangle ends up in four lines.
I must have changed something but can not find what.
Thanks for pointing me in the right direction.
Re: When drawing an rectangle it ends up in four lines
Post by CVH » Wed Sep 23, 2020 5:59 pm
After you select the tool ...
look at the options bar, left high.
There should be the option to create it as a poly.
MxV
Post by MxV » Thu Sep 24, 2020 2:34 pm
Hallo,
Found it :D
Thanks.
Marnix
