Show one object in front of another
How do I show one object in front of another? For example. If I use a a draw-rectangle to draw a vertical 2x4 wood piece and then draw a horizontal 2x4 wood crossing over the vertical piece. Where they cross how do I hide the lines of the vertical 2x4, similar to the sample picture?
- sample to explain my question
- sample cross over.jpg (15.6 KiB) Viewed 5679 times
Re: Show one object in front of another
Select the entities and use "Bring to Front" or "Bring to Back"
Menu / Modify / Draw Order / ...
Hi Husky, I have been trying that but nothing changes. puzzled.
attached is a picture of the step sequences I am trying. Hopefully you can spot what I may be doing wrong or missing.
- test to send to back.jpg (173.91 KiB) Viewed 5671 times
You need to hatch (solid) at least the rectangle which has to be in front to block visually the other rectangle.
A vector has no 'thickness'
4 line entities won't 'cover' other line entities
Although if you gave the vector a width or a line weight it can.
That is handled by the draw order.
If you want surfaces to cover each other, you will have to draw something that might be considered as a plane.
A Hatch will do. Faces and solids too.
Regards
Regards
In CAD filling with a solid hatch to cover lines doesn't make sense.
The better way is to trim the lines (see tool D2)
TSG
TSG
Indeed, but I suspect a non-CAD related use.
(Drafting on Paper space)
