[solved] Lines in blocks disappearing at zoom level
massimo
Post by massimo » Tue Apr 14, 2020 10:24 am
I'm using Community Version: 3.24.3.0 (3.24.3), self built from sources with x86_64-pc-linux-gnu-9.3.0 and Qt-5.14.1-r1.
I create help lines of infinite length inside a block, layer is "helplines", red, 0,25mm, DOT(2x). Inside the block I can see the lines at any zoom level. Leaving the block editor, the lines are getting shorter when zooming closer. Zooming far away the lines look like infinite length, zooming closer, the lines look like cut shorter, and zooming very close, the lines disappear completely.
What setting is wrong here? Are lines hidden at closer zoom levels for performance reasons? Restarting qcad shows the same issue.
Community Version 3.28.2.0, Gentoo Linux on amd64
Re: Lines in blocks disappearing at zoom level
Post by Husky » Tue Apr 14, 2020 7:11 pm
Reproducible - thanks.
Infinitive lines in blocks are displayed shortened in Model_Space. I would consider that a bug which pertains the QCAD Pro version too.
Please file a bug report below:
Thank you.
massimo
Post by massimo » Wed Apr 15, 2020 6:05 am
