Dimension properties
Quasar999
Post by Quasar999 » Sat Mar 28, 2020 2:29 pm
How i could change the properties of a dimension? Using the properties box i couldn’t see the text type and size value.
Re: Dimension properties
Post by CVH » Sat Mar 28, 2020 2:50 pm
These are aplied for the full document.
See:
Menu..Edit..Drawing Preferences (Ctrl+I) >> Dim Settings
That is for the current document.
The general prefs are at:
Menu..Edit..Application Preferences (Ctrl+,) >> Dim Settings
The red text is self explanatory.
Quasar999
Post by Quasar999 » Sat Mar 28, 2020 4:00 pm
I'v already tried that way but i change the properties of all dimensions. Moreover i can't change the text style and value.
Post by CVH » Sat Mar 28, 2020 4:19 pm
text style :
Meaning individually...No
Pritty common to use a global style for all the dims in a drawing.
Meaning in one or both Preference widgets...
That would be odd.
The value of the dimension is the 'Label' property.
Auto means the measurend value.
This can be any text, something<>, <>whatever or something<>whatever
Here <> is a placeholder for the measured value.
There is still the option of exploding a dimension to Faces-Lines-Text.
However, you will loose the link with the measured value by doing so.
Quasar999
Post by Quasar999 » Sat Mar 28, 2020 4:54 pm
Thx very much for the fast reply. What about font style?
Post by CVH » Sat Mar 28, 2020 5:13 pm
Meaning Bold, Italic and so on ... No
>> The size can be altered individually by the Dim its Specific Property 'Scale'
Exploded to Text ... Yes
Quasar999
Post by Quasar999 » Sat Mar 28, 2020 9:11 pm
I mean font type like Arial or Times New Roman.
Post by CVH » Sat Mar 28, 2020 9:30 pm
See Drawing or Application Preferences
That was mentioned higher.
Quasar999
Post by Quasar999 » Sun Mar 29, 2020 3:33 pm
Really sry to bother you so much but i can't find the menu entry to change the font type of the dimensions. I check in the Application setting and in the drawing settings and seems that only in the last one i could modify some parameter for the dimansions but not the font type.
When i talk of the font type i mean the shape of the number in the label like:Arial, Times New Romans and etc.
Panchdara
Post by Panchdara » Sun Mar 29, 2020 3:55 pm
Sorta like this??
Windows 10
Quasar999
Post by Quasar999 » Sun Mar 29, 2020 4:56 pm
This what i see.
Post by CVH » Sun Mar 29, 2020 5:32 pm
Your topic in was in the Pro section.
Please always mention Qcad version and platform.
See Forum Rules at the top.
See:
https://qcad.org/en/documentation/features
Scroll down to •Construction ◦Dimensions
'Configurable dimension font' is in blue = Pro feature
Sorry, You will need a pro licence for that.
Don't let the small fee discourage you!
Panchdara
Post by Panchdara » Sun Mar 29, 2020 5:42 pm
I can't agree with CVH more... the small fee for QCAD is so worth it.
Best
Windows 10
Quasar999
Post by Quasar999 » Sun Mar 29, 2020 9:25 pm
Sry. My Bad.
Post by Husky » Sun Mar 29, 2020 9:50 pm
Topic moved from "QCAD Professional Version" to "QCAD Community Edition"
