I have many files done in AutoCad and am now changing to QCAD. Using a DWG to DXF converter I have now all the files in a DXF format. Propblen is the dimension sizing need to be changed which is no problem. The problem is after getting the dim. to the size I need any new dim. added to the drawing comes out a different scale (size). Also I am working with large drawings 300 ft. by 300 ft. and it will not allow me to use Architectural or Engineering formats, eveything is shown in inches. Attached is snips of problem.
Thanks Dan
Solved Dimension problem
Re: Dimension problem
Found my problem with second problem and can now use Architectural mode.
