Unable to change background colour. (unsolved - re-installing Qcad)
Jim0000
Post by Jim0000 » Mon Dec 16, 2019 9:36 pm
I have installed Qcad into my laptop computer. Using Linux Mint 19
I removed the plugins to retain only the community version. I have done this before on both my desktop computers successfully.
All good, except that I now cannot change the page background colour. I have tried changing it in both "Drawing Preferences" and "Application Preferences" without success.
I am beginning to suspect that I removed one file that I should not have.
Unfortunately, I emptied my trash folder too quickly; I formerly retained the contents to check myself.
I would like some suggestions please. Before I resort to removing Qcad and re-installing it more carefully.
Jim.
Re: Unable to change background colour.
Post by Husky » Mon Dec 16, 2019 10:33 pm
You are only able to change the Background color within "Application Preferences".
If that doesn't works then I would recommend to de-install / new instal QCAD. Assumably the less Headaches route ... :wink:
Jim0000
Post by Jim0000 » Tue Dec 17, 2019 12:11 am
Thanks Husky.
I have tried that and it does not work. So, I will uninstall and install Qcad again.
Jim.
Jim0000
Re-installed Qcad.
Post by Jim0000 » Tue Dec 17, 2019 2:20 am
I get the same result after a removal and re-installation of Qcad.
What can I try next please?
Re: Re-installed Qcad.
Post by Husky » Tue Dec 17, 2019 3:59 am
1. Double check that you downloaded and installed the correct package for your Operation System:
https://www.qcad.org/en/qcad-downloads-trial
2. Make sure that you followed the installation tutorial by the letter:
https://qcad.org/en/documentation/installation
3. Reset the QCAD Configuration:
Jim0000
Problem persisting.
Post by Jim0000 » Tue Dec 17, 2019 10:24 pm
Thanks again Husky.
I satisfied points # 1 & 2 - all confirmed. Removed and re-installed the correct file again.
However, I could not find the configuration file in my download. I did a file search: no such file found.
It is starting to look like I will have to live with this slight anomaly. As long as nothing else shows up as non-functional or not available, after all it is a relatively minor problem.
Jim.
Re: Problem persisting.
Post by Husky » Tue Dec 17, 2019 10:58 pm
I'm not familiar with Linux but I don't think that the CAD3.conf file is part of the download package. It will be created with the first start of QCAD and should then be below: ~/.config/QCAD/QCAD3.conf
Jim0000
Post by Jim0000 » Wed Dec 18, 2019 9:17 am
......................... It will be created with the first start of QCAD and should then be below: ~/.config/QCAD/QCAD3.conf
Yes. File not found, as I said above.
Jim.
Post by Husky » Wed Dec 18, 2019 10:03 am
Ok, please let us do a last test: Open QCAD CE, toggle the visibility of the "Status Bar" (Menu/View/Status Bar) which will be displayed at the bottom of the Model_Space. Remember the new Status (Visible or invisible), close QCAD CE, launch QCAD CE again. Will QCAD Start with the last used visibility status of the Status Bar?
Jim0000
Post by Jim0000 » Sat Dec 21, 2019 3:42 am
Thanks for hanging in there with me Husky.
However, all the above is incomprehensible to me; just for starters, I don't have a clue what "QCAD CE" is ???
Do you mean the community edition?
After removing the trial add ons in the plugin folder? (Like I have already done)?
And what is "Model_Space" ??
I am about to abandon this thread as insolvable. I will wait for your reply before doing so.
I have three installations of the Community Version of Qcad and never had this problem before.
Jim.
Post by Husky » Sat Dec 21, 2019 8:20 am
Sorry for that! Yes, that is the Community Edition
That is the area on what you draw. Most likely with a black background.
Do you have now all info's for this little test?
Jim0000
Post by Jim0000 » Sat Dec 21, 2019 9:21 pm
Yes, I think so.
Thanks.
I'll try it today.
