Remove trial pro problems: Win 7 64 bit
OldNick
Post by OldNick » Mon Dec 09, 2019 4:54 am
I have downloaded the trial version 3.21.3.0 (3.21.3) into Win 64 bit. I like its transparency and ease of use. About says it is the Community Edition.
I tried it out intermittently (that is pretty much how I will use it), then I reinstalled it. Now every now and then it says Trail Expired and QCAD crashes, losing what work I have done.
I have read two sorts of instructions about removing the programme: the first is removal if files in the plugins folder of QCAD...the files are not there.. The second is to deselect the options i the Trial Widget...I cannot see a Trail widget and do not remember ever seeing one. If I ask to View/Toolbars and widgets/Widgets, the Trial is not listed.
So I am a bit stuck! Could anyone help, please?
Thanks in advance.
Nick
Re: Remove trial pro problems: Win 7 64 bit
Post by CVH » Mon Dec 09, 2019 11:23 am
Normally there would be a widget...
I would start overnew.
Remove Qcad completely including the Win ini file.
Maybe you could search for some post about removing the program as an extra guide.
From a clean slate:
Download and install the trial pro package of your preference.
And use the first post in this section to remove the trial pro features.
Kind Regards,
OldNick
Post by OldNick » Tue Dec 10, 2019 2:53 am
Thanks for the reply.
Weirdly, the next time I opened it it is working fine. I deliberately left it open all night, with a picture loaded, and it's fine.
I don't remember seeing that Community Edition in the About before, so something has fixed itself. :|
Nick
Post by CVH » Tue Dec 10, 2019 7:29 am
Probably restarting was all you needed to do more. :D
