Snapping on center of a rectangular shape (4 lines)
Krischu
Senior Member
Post by Krischu » Sun Jul 07, 2019 11:29 am
Bildschirmfoto 2019-07-07 um 12.25.11.png (14.35 KiB) Viewed 2262 times
I want to put a drill hole (small circle) in the midpoint of a rectangle (formed of 4 separate surrounding lines). How can I adjust the snap mode such that the cursor snaps to the midpoint of the (green marked) area?
Christoph
Re: Snapping on center of a rectangular shape (4 lines)
Post by Husky » Sun Jul 07, 2019 5:19 pm
In this particular situation you can use the "Center of Selection" snap. In other situation the "Middle Manual" snap will provide the solution.
Krischu
Senior Member
Post by Krischu » Mon Jul 08, 2019 7:13 am
Thanks. Found it in the drop down menu (SK). Does not appear in the left icon bar.
Christoph
