I have a black dot on a line in this drawing. When I print it out, the dot becomes a larger circle. In this case, it is equivalent of around 30mm in the scale that the drawing is printed. The dot is on the line under #10. It looks insignificant on the drawing, but large on the printed version.
Can someone explain what this is and how I remove it please?
I will attach both a screenshot and a .dxf file of the drawing.
Unable to remove black dot in drawing. (solved)
- Elliptical tip panel.dxf
- (97.16 KiB) Downloaded 457 times
- Black dot mystery.png (16.66 KiB) Viewed 5875 times
Re: Unable to remove black dot in drawing.
It's a zero diameter circle on layer 0. I was able to window select and delete it...?
Len
QCAD Pro
QCAD Pro
Ok, thanks Lphilpot.lphilpot wrote:It's a zero diameter circle on layer 0. I was able to window select and delete it...?
Sorry for my late reply!
