Hi all.
QCAD 3.16.2 is now officially packed for Fedora Project on Fedora>=24.
Homepage of the RPMs: https://admin.fedoraproject.org/pkgdb/p ... rpms/qcad/
Homepage on Fedora Apps: https://apps.fedoraproject.org/packages/qcad
if you use Fedora as main S.O. and bump into a packaging bug, please open a bug report on bugzilla.redhat.com or into this forum.
QCAD is available for testing for next 8 days, then pushed into stable repositories if everything works.
Regards.
QCAD 3 on Fedora
Re: QCAD 3 on Fedora
Thanks sagitter!
Just a footmark: This is the free QCAD Community Edition. If you are using QCAD Professional, please download always from your personal download link sent to you by e-mail.
QCAD Professional is not released with open code; i can pack QCAD Community Edition only.
Yes exactly. That's what I tried to tell the interested users heresagitter wrote:QCAD Professional is not released with open code; i can pack QCAD Community Edition only.
This forum is for QCAD professional
I realized just now.
No worries, I've moved it to the QCAD Community Edition forum, leaving a shadow topic in place.
