Good Evening,
I have recently installed the latest build of QCad 3.9.8.0 and every time I close any drawings, the message about saving the changes before closing the drawing pops up. Is it an installation problem or an application preferences that I need to adjust?
The weird problem is that it only happens when I am using QCad on Ubuntu and not on Win 7. I installed the current QCad build on both OS and the Win 7 version doesnt have the message when compared to the Ubuntu version. Other than this small problem, everything else works great.
My current setup is a Lenovo Thinkpad running a dual boot system, Windows 7 and Ubuntu 14.04LTS. The OS's are 64 bit with all the updates installed.
Thanks for any help
closing drawing, save the changes
Re: closing drawing, save the changes
Is this QCAD Professional or the QCAD Community Edition? Thanks.
sorry, I forgot to include that its the community edition.
No problem. I've moved this topic to the appropriate forum.
I've had exactly the same problem, under Linux, since about version 3.7.3 (Community version). Yesterday I made a discovery. I decided to install the Pro Trial version in Windows 8.1, and remove the pro libraries, so as to have the Community version installed. When I had removed the libraries, the exact same problem appears in the Windows version. So, I put back the proscripts library, and the problem disappeared.
It would appear that something was removed from the community version and put in the pro scripts library.
@Andrew - Should I enter a bug report or is this a fairly easy fix?
riverbuoy
riverbuoy
This is a known problem with QCAD CE, yes. Feel free to report a bug and assign to "QCAD Community", thanks.
