When editing such a layer, opening the custom color again for copying the color code in order to create a new layer of the same color, QCad is always crashing:
(process:19053): Gtk-CRITICAL **: 11:33:23.668: _gtk_css_lookup_resolve: assertion '(((__extension__ ({ GTypeInstance *__inst = (GTypeInstance*) ((provider)); GType __t = ((_gtk_style_provider_private_get_type ())); gboolean __r; if (!__inst) __r = (0); else if (__inst->g_class && __inst->g_class->g_type == __t) __r = (!(0)); else __r = g_type_check_instance_is_a (__inst, __t); __r; }))))' failed
(process:19053): GLib-GObject-CRITICAL **: 11:33:23.668: g_object_set_data_full: assertion 'G_IS_OBJECT (object)' failed
(process:19053): Gtk-ERROR **: 11:33:23.668: Can't create a GtkStyleContext without a display connection
Trace/breakpoint trap
Version:
3.28.2.0 (3.28.2)
Internet:
QCAD.org
Erstellungsdatum:
Sep 15 2023
Revision:
Qt Version:
5.15.10
Architektur:
x86_64
Compiler:
gcc 12.3.1
