Running Scripts [SOLVED]
Joseph1916
Post by Joseph1916 » Sat Jul 15, 2023 6:14 pm
Operating System: Ubuntu 22.04
Program: QCAD 3.28.1 Community Edition
Testing out my Ubuntu 22.04 and QCAD Community Edition.
Entered Misc Drop Down menu > Script Shell appeared properly seemed to execute one line at a time FINE
Entered Misc Menu > Run Script Open > Dialog Box Appeared > Selected Script File > But nothing happened.
I'm on Community Edition, Is that an issue??
Re: Running Scripts
Post by CVH » Sat Jul 15, 2023 6:52 pm
Have you an example script to share ... :?:
You my also PM 'Personal Message' the example if that is more convenient for you.
Joseph1916
Re: Running Scripts
Post by Joseph1916 » Sat Jul 15, 2023 11:47 pm
Its the example provided: (without the comments)
a=7; b=6;
phi=0.2*Math.PI;
step=Math.PI/256;
w=100;
h=100;
v=[];
for (t=0.0; t<Math.PI*2; t+=step) {
// compute next x,y coordinate:
x = w * Math.sin(a*t + phi);
y = h * Math.sin(b*t);
// append coordinate to our array of coordinates:
v.push([x,y]);
addSpline(v, true);
autoZoom();
Joseph1916
Re: Running Scripts
Post by CVH » Sun Jul 16, 2023 5:23 am
Joseph1916,
One can paste several lines of code to the bottom line of the Script Shell in one go.
These are executed the same way as if they where in a script file.
For saved scripts the file extension *.js is even not mandatory.
Yes and no.
addSpline(...); is part of the Simple API and draws a fitpoint spline.
CE only supports control point splines.
You could replace addSpline(...) by addPolyline(...)
Then you get an approximation by line-segments what looks about the same there the points cloud is dense enough.
To be able to draw fitpoint splines the only advice is to upgrade to QCAD PRO :wink: or to use the trial version.
Joseph1916
Re: Running Scripts
Post by Joseph1916 » Sun Jul 16, 2023 5:56 pm
Hi CVH;
SOLVED !!! I worked on my own attempts, They were not the issue, but the addPolyline( ... ) did the trick.
On to learn more, and I feel I will go to the Professional after I get more experience ......
Thanks for the strong support...
Joseph1916
Joseph1916
Re: Running Scripts
Post by Joseph1916 » Sun Jul 16, 2023 9:10 pm
CVH,
Hey
My objective with QCAD is to create a a 2d JavaScript array database of Point values that will be assigned Point Numbers contained in Column 1 of the 2d array. Column 2 3 and 4 will be the XYZ of the respective Points. Column 5 would be a description.
I was a Survey Engineer, with no Software but Civil 3D, and that is not for Surveyors, And its price is outrageous.
Joseph1916, Retired Surveyor
Re: Running Scripts
Post by CVH » Sun Jul 16, 2023 11:04 pm
Joseph1916,
QCAD PRO comes with a powerful script developed by Andrew: Import Points with Labels ...
Have a look here:
https://qcad.org/en/tutorial-importing- ... s-from-csv
Various kinds of points can later be stored to use as coordinate input data for creating splines/polylines ... For inserting blocks ... And so on.
https://qcad.org/en/tutorial-reusing-drawing-positions
Exporting things in a drawing to CSV can already be done by an OS Command Line tool dwg2csv:
https://qcad.org/en/products/qcad-command-line-tools
That CSV data may require some polishing up. :wink:
Joseph1916
Re: Running Scripts
Post by Joseph1916 » Wed Aug 02, 2023 7:43 pm
Scripts supporting ExMyMinimal.iu Code:
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0">
<class>ExMyMinimal</class>
<widget class="QWidget" name="ExMyMinimal">
<layout class="QHBoxLayout">
<item>
<widget class="QLabel" name="RadiusLabel">
<property name="text">
<string>&amp;Radius:</string>
</property>
<property name="buddy">
<cstring>Radius</cstring>
</property>
</widget>
</item>
<item>
<widget class="RMathLineEdit" name="Radius">
<string notr="true">1</string>
</property>
</widget>
</item>
</layout>
</widget>
<customwidgets>
<customwidget>
<class>RMathLineEdit</class>
<extends>QLineEdit</extends>
<header>RMathLineEdit.h</header>
</customwidget>
</customwidgets>
<resources/>
<connections/>
</ui>
Re: Running Scripts
Post by CVH » Thu Aug 03, 2023 5:48 am
Joseph1916,
.... See the topic above ....
I can not comprehend how and why this will not work for you ... :shock:
Below is the exact same text as in the post above.
Simply copied whole your topic content and pasted it in the reply topic text box:
<ui version="4.0">
<item>
</property>
</property>
</widget>
</item>
<item>
</property>
</widget>
</item>
</layout>
</widget>
<customwidgets>
<customwidget>
</customwidget>
</customwidgets>
<resources/>
<connections/>
</ui>
Seems to look well formatted as code when I do it.
Sure, indentations are removed in your post as do all leading spaces in plain text.
That won't happen if the text is in a code box. :wink:
