Post Processors - Centroid
scarab4t
Post by scarab4t » Tue Nov 08, 2022 5:45 pm
is there a specific post processor for Centroid Acorn ... would like to know pre purchase
Re: Post Processors - Centroid
Post by CVH » Tue Nov 08, 2022 6:53 pm
I don't think you need a special postprocessor.
All depends on the G-code dialect that is supported by the Centroid Acorn.
Of course one can create a custom postprocessor if that would be required.
scarab4t
Post by scarab4t » Tue Nov 08, 2022 8:53 pm
@CVH
Thanks for response. Any info on post processor creation would be more than welcome
Post by CVH » Mon Nov 14, 2022 6:09 pm
There is not much to go on ...
https://qcad.org/en/qcad-cam-postprocessor
But you can get help with very specific questions in this forum.
