I am running Qcad/Cam 3.27.8.0 on Windows 11, 64 bit.
Does anyone know about proper formatting for the CSV file when trying to import a tool table file? This is under the CAM toolbar, Import tools.
I notice that the export tools option does not allow to write to a CSV file, which is fine, but then I could have had an idea of the formatting required.
This is the lowest priority!! Just looking to make things a little cleaner on my end when working with other co-workers DXF files....
Thank you.
[Solved] Import CSV tool table file
- Import CSV tool table file.jpg (63.41 KiB) Viewed 7858 times
Re: Import CSV tool table file
This is now an even lower priority. I just found the thread below about having DXF files in the post processor folder, that tie into the currently selected post processor. I'm going to try going this route for now, and may be better long term.
Thank you.
https://qcad.org/rsforum/viewtopic.php? ... ols#p36829
Thank you.
- Default tools.jpg (77.28 KiB) Viewed 7854 times
