I am writing again regarding the way the tabs are generated. Recently, I was designing a simple detail (foot for my device). Detail was intended for milling. The milling was planned in three steps: cutting the central hole, cutting the entire detail along the outer contour and chamfering the upper edge. Chamfer line was inside of the detail (0.5 mm from the contour line). There were three tabs added on the contour line. After generating the gcode, it turned out that the tabs are also on the chamfer path, although chamfer was supposed to be cut separately at a different height (see simulation1.jpg). I added a few more paths (just to see what happens) and tabs appeared on two more. The distance between the last path with tab to the one where the tab was originally located was 1.5 mm - exactly half the diameter of the cutter (see simulation2.jpg). So it seems that the tab is generated in such way that it covers a width equal to the width of the cutter. However, still there is an inaccuracy: when milling is planned outside of the contour line, tab should not cover other areas of the detail. Of course, one can deal with it and generate the correct gcode, but the whole procedure is not very intuitive and - in my opinion - it should be corrected in the next versions of QCADCAM. Gcode should be affected by the tab only for the contour line where the tab was really placed.
Best Regards
Konrad
QCADCAM 3.27.6
Win10
Tabs - again
Tabs - again
- simulation1.jpg (321.72 KiB) Viewed 9799 times
- simulation2.jpg (465.7 KiB) Viewed 9799 times
- stand1.dxf
- (855.87 KiB) Downloaded 284 times
Re: Tabs - again
Hi Konrad,
https://www.qcad.org/rsforum/viewtopic. ... tab#p36162
Looks good to me ...
Well, a while ago it was bothering me too but you helped me to find a workaround. Thanks for that! I'm wondering why your own workaround isn't working anymore for you.
I agree! It would be nice to have an easier solution to set tabs accurately to a chosen paths. Did you file a Feature request below www.qcad.org/bugtracker ? That would be the right place to ask for it ...
Re: Tabs - again
Husky wrote: ↑Sun Sep 04, 2022 11:17 pmI agree! It would be nice to have an easier solution to set tabs accurately to a chosen paths.
Husky, you filed a Feature Request on 15.01.2022
https://www.ribbonsoft.com/bugtracker/i ... sk_id=2331
Re: Tabs - again
Some insights:
Bridges will be added at any profile crossing TAB markers above the zFinal of that profile.
- These markers are simply block references on layer 'CADCAM' and the Block 'CamTab' is made up of 2 solid Hatches on layer 0.
- TAB markers have 3 custom properties: "Tab" =1; "Tab Length" & "Tab Thickness".
Profile A may have a zFinal of -18.2 while Profile B its zFinal is -9 and then zFinal of A is not taken into consideration when processing B.
Both profiles sources are in 2D while resulting cutter paths have z values.
As long as QCAM is not aware how thick your piece is ...
... And/or doesn't cross-evaluate all zFinals ...
... It can't know if profiles are stacked in X/Y.
The main solution here is that TABs are made profile depending.
A different solution to this would be an extra marker property that holds the bottom Z value of the TAB.
Given that 'zBottom' is -18.2 all passes of Profile B will never trigger adding bridges.
We could add a profile C and also regenerate profiles when required.
'zBottom' can be sourced in different ways:
- User input on TABs.
- User input of material thickness.
- Lowest zFinal of all profiles.
If we look closer to simulation2.jpg we see that only the 3 outer chamfer paths make bridges.
Indeed, TABs have a certain width.
A tab position is accompanied by a cutting line through the tab position, orthogonal to the shape and extend to both sides by the tool radius.
Any profile shape that intersects with this line will trigger adding bridges.
Again, profile dependency or a 'zBottom' would be a solution.
Re: Tabs - again
Hi Husky,
I remember my own post but this time the case was slightly different .
Regarding the topic: thank you for your all answers. IMHO the simplest solution is to tie the tab to a given line, without any tab width (or more precisely, tie it to a given tool path). The width will be always depended on the cutter diameter. This will allow to create more complex paths, even overlapping one another. It should be on the side of the operator to remember about maintaining (or not) the tab width, during milling.
At least it should be possible to turn off the tab width (or set to zero) to leave it tool dependent only.
Best
Konrad
Best
Konrad
Re: Tabs - again
just to show what the fuss is about
Regards
Konrad
Regards
Konrad
- Detail1.jpg (52.23 KiB) Viewed 9691 times
