If toolType
Claudiosp
If toolType
Post by Claudiosp » Fri Jul 29, 2022 4:12 pm
Nee some help this not work
BIESSE.prototype.writeBlock = function(name) {
    if (toolType===Cam.ToolType.Drill) {
        // Drill
		this.toolHeader = [];
		this.firstPointMoveZ = ["[N] [X] [Y-] T[T] VF=[FP] PRF=[Z-] L=G99", ];
   // call base class to write the text block:
    GCodeBase.prototype.writeBlock.call(this, name);
Re: If toolType
Post by andrew » Fri Jul 29, 2022 4:22 pm
toolType is not defined in this function. You should also set the text blocks for other tool type, otherwise they will change for the first drill tool and never change back.
    // get current tool type:
    var toolType = this.getCurrentToolType();
        // Drill
	else {
	   // fill in text blocks for other tools:
	   this.toolHeader = ...
	   this.firstPointMoveZ = ...
Claudiosp
Re: If toolType
Post by Claudiosp » Fri Jul 29, 2022 5:34 pm
this not work
Braço Sofá.dxf
(246.2 KiB) Downloaded 285 times
BIESSE.js
(7.96 KiB) Downloaded 277 times
Re: If toolType
Post by CVH » Sat Jul 30, 2022 6:04 am
this not work
A shot in the dark:
this.firstPointMoveZ is set to an array [...].
A comma separates each member of an array [AAA, BBB, CCC].
Here AAA is a string "[N] [X] [Y-] T[T] VF=[FP] PRF=[Z-] L=G99" and there is no second item.
That would then default to 'Undefined'.
This also occurs in this.fileExtensions, in this.header and in this.contourFooter. :wink:
Things in the output text between square brackets are replaced by their current value, the rest is treated as literal.
e.g. the "L=G99" at the end of this.firstPointMoveZ.
Claudiosp
Re: If toolType
Post by Claudiosp » Sat Jul 30, 2022 9:53 am
Tks for reply.
I problem i have is when i need use drill this.toolHeader = []; but i create if AGGREGATE10 is this else that i just want remove this.toolHeader = []; when use drill.
Re: If toolType
Post by CVH » Sat Jul 30, 2022 4:37 pm
Means that the header for a tool is defined as an empty array ...
... In other words nothing is exported to the G-code as tool header.
From what I can make up of your reply, that would be the case for drilling.
The function BIESSE.prototype.writeBlock is called every time something is being written.
Remark that this function is declared twice In the BIESSE.js of your post above.
You initialy reported that this.firstPointMoveZ doesn't work ....
... Simply because the writeBlock function is overwritten by the second duplicate.
In the second one this.toolHeader is in both cases set to "[N] PAN=1 ST1=\"[T]\" L=PCUA" ...
... and this.firstPointMoveZ does not occur at all.
In the other topic Andrew remarked that you do not move all the code to the BIESSE.prototype.writeBlock ...
... For example, register all your variables in the main class and surely not only once in an if-else clause.
