Condition
Claudiosp
Condition
Post by Claudiosp » Sat Jul 16, 2022 12:07 pm
Hi I need some help
I need make a condicion IF on post
if toolname===AGGREGATE10
[N] PAN=[NUMBERTOOL] UT=1 XIN=[START_X] YIN=[START_Y-] TID=1 XFI=[END_X] YFI=[ENDY-] PRF=[-Z-] VT=[FP] VF=[F] INV=0 USC=0 RES=1 Z=PRK L=G102
ELSE
NORMAL CODE
Re: Condition
Post by andrew » Wed Jul 20, 2022 11:25 am
Do you already have a post processor and are you trying to add this to it? If so, please attach. Or are you starting from scratch? Thanks.
Claudiosp
Re: Condition
Post by Claudiosp » Wed Jul 20, 2022 12:16 pm
Hi Andrew is this BIESSE.
BIESSE.js
(4.53 KiB) Downloaded 278 times
Re: Condition
Post by andrew » Thu Jul 28, 2022 10:55 am
Thanks.
Is it the text block this.contourHeader that would be adjusted, depending on the tool?
In general, you would change the contents of that text block, depending on the tool before the text block is written to the file:
BIESSE.prototype.writeBlock = function(name) {
    if (this.getCurrentToolName()==="AGGREGATE10") {
        // tool is AGGREGATE10
        this.contourHeader = [ "[N] PAN=..." ];
    else {
        // tool is not AGGREGATE10
        this.contourHeader = [ "[N] PAN=1 ..." ];
    // call base class to write the text block:
    GCodeBase.prototype.writeBlock.call(this, name);
Claudiosp
Re: Condition
Post by Claudiosp » Thu Jul 28, 2022 4:55 pm
I have problem on tool correction
When is AGGREGATE10 IS SAW need tool compensation without G41/G42
And old BUG when I change tool direction I need close QCAD and Open again for do correct NC.
I use last Version o QCAD
BIESSE.prototype = new GCodeBase();
this.registerVariable("xStartPosition", "X1", true, "", "DEFAULT", "DEFAULT");
this.registerVariable("yStartPosition", "Y1", true, "", "DEFAULT", "DEFAULT");
this.registerVariable("zStartPosition", "Z1", true, "", "DEFAULT", "DEFAULT");
this.registerVariable("xPosition", "X", false, "", "DEFAULT", "DEFAULT");
this.registerVariable("yPosition", "Y", false, "", "DEFAULT", "DEFAULT");
this.registerVariable("zPosition", "Z", false, "", "DEFAULT", "DEFAULT");
this.outputOffsetPath = true;
this.contourHeader = [ "[N] PAN=1 ST1=\"[T]\" L=PCUA",
"[N] PAN=1 UT=1 XIN=[X1] YIN=[Y1-] TID=1 XFI=[X] YFI=[Y-] PRF=[Z-] VT=[FP] VF=[F] INV=0 USC=0 RES=1 Z=PRK L=G102" ];
this.zPassFirstHeader = [];
this.zPassHeader = [];
this.firstLinearMove = [];
this.linearMove = [];
this.footer = ["%"];
this.contourFooter =[];
this.linearMoveCompensationLeft = [];
this.linearMoveCompensationRight = [];
this.linearMoveCompensationOff = [];
else {
this.outputOffsetPath = false;
this.contourHeader = [ "[N] PAN=1 ST1=\"[T]\" L=PCUA" ];
this.zPassFirstHeader = [ "[N] [X1] [Y1-] Z=PRK TP=1 PRF=[Z1-] F=[F] VF=[FP] G40 L=PON TRZ=0 M55"];
this.zPassHeader = [ "[N] [X1] [Y1-] Z=PRK TP=1 PRF=[Z-] F=[F] VF=[FP] G40 L=PON TRZ=0 M55 "];
this.firstLinearMove = [ "[N] G1 [X] [Y-]"];
this.linearMove = [ "[N] G1 [X] [Y-]"];
this.footer = [
"[N] G0 L=POFF",
this.contourFooter = ["[N] L=POFF",];
this.linearMoveCompensationLeft = [ "[N] G42 G69 [X] [Y-] G1 "];
this.linearMoveCompensationRight = ["[N] G41 G69 [X] [Y-] G1 "];
"[N] G40 [X] [Y-] G1 ",
"[N] L=PSU",
Re: Condition
Post by andrew » Fri Jul 29, 2022 4:24 pm
You moved all the code from the constructor into writeBlock. This is not the idea (please see post above). writeBlock should only change the text blocks you want to change and call the base class to write the text block.
Claudiosp
Re: Condition
Post by Claudiosp » Fri Jul 29, 2022 5:08 pm
I do this because they repete some code.
Show me how do this
else {
this.footer = [
"[N] G0 L=POFF",
"[N] L=PSU",
