cam tool, cam tool path UI when using a dark tgeme
fdixon
Post by fdixon » Sun Apr 10, 2022 9:03 pm
Can't see text in these 2 dialogs using a dark theme. I can see it if I select it, that is how I am using it.
I have the theme creator a try but I did not see a change.
Every no and then it will open with light text. Just happened. I was making a new tool block going back and forth from the drawing to a saved block file in the library, editing the block file.
Win10
Qcad/cam 3.27.1
Current theme midnight.
Re: cam tool, cam tool path UI when using a dark tgeme
Post by andrew » Mon Apr 11, 2022 9:06 am
Please try the "Default" theme or the "Dark" theme instead.
Please post a screenshot if the problems persist.
