Hello all.
First post here and I'm new to this stuff, but learning I have been cad-drawing for quite some time and usually I get by decently.
I'm building my own cnc-mill/router and then of cource I will need to learn CAM as well. So started fiddling around and all seemed to be coming along fairly good. That's up till the point when I saw that I was doing CAM in .DXF
I'm planning to use "Pumotix" as the control soft/hardware and when reading up on what G-codes where supported I got a little confused
There are G-codes from 0 to 99 and from reading the list they all seem to have a specific task.
Now I'm really hoping that I will not have to change CAM export settings for every single different process.
I remember reading here somewhere that if the controlling software was able to understand for instance G41/42 I should be good to go.
Would I be ok if making all toolpaths in G-41/42 mm ?
Edit: I'm on Windows10 using QCAD/CAM 3.26.4. Postprocessor "G-code G41/G42 mm".
Link: http://doc.pumotix.ru/display/PUMENG/Li ... the+System
Cam configuration G-codes ?
- amplifiers cam.png (198.43 KiB) Viewed 3747 times
- amplifiers cam.dxf
- (2.57 MiB) Downloaded 262 times
Re: Cam configuration G-codes ?
Yes, if your controller supports these, you can use G41/42 for tool radius compensation. Alternatively, computed offsets can always be used (post processors with "(Offset)" in the name). There are advantages and disadvantages for both systems.
