When I open a file with a Toolpath in QCAD, I can select the CAM Simulation panel and it works normal.
However, if I close that file and open another drawing, the CAM simulation panel will not start again. It will only work if I first close and restart QCAD.
To test I made two small files (attached). Open the first one, CAM simulation works; close it file and open the second one, CAM simulation will not start.
Regards, Robert
QCAD/CAM on Linux Mint 20
Version:
3.26.2.0 (3.26.2)
Build Date:
Apr 13 2021
Revision:
57092ea
Qt Version:
5.14.2
Architecture:
x86_64
Compiler:
gcc 5.4.0
CAM simulation problem
- qcad-gcodetest3.dxf
- (115.89 KiB) Downloaded 404 times
- qcad-gcodetest4.dxf
- (113.14 KiB) Downloaded 420 times
Linux Mint 20 , qcadcam-3.24.3.10-pro-linux-x86_64
Re: CAM simulation problem
A related bug (?)
If I have a drawing with several different tool paths and start the Simulation Panel, the panel will always play the first toolpath, independent of which toolpath is enabled / selected.
Robert
Robert
Toolpath visibility has currently no effect on simulation. This might change at one point.
