Nesting Bug
fab
Nesting Bug
Post by fab » Mon Apr 12, 2021 2:39 pm
hi,
think i detected a bug in nesting:
when trying to nest a single part into two sheets, where one of them ist to small for the part and its position is more "left" than the bigger one, then the nesting ist not possible, although theres enough space in the bigger one.
Scrrenshot an example dxf in attetechment.
Version:
3.26.1.0 (3.26.1)
Internet:
QCAD.org
Erstellungsdatum:
Mar 8 2021
Revision:
eec8166
Qt Version:
5.13.2
Architektur:
x86_64
Compiler:
MSVC++ 14.0 (2015)
part.dxf
(105.93 KiB) Downloaded 383 times
sheet.dxf
(106.6 KiB) Downloaded 411 times
