I am in the need of two variables that increment by 1, each time they are called up.
I am using the 'N' linenumber as as one of the variables.
I made another variable in the JS file, and called it eventnumber.
It does show in the post, but does not increment.
I have some screenshots attached for reference.
Thank you.
P.S. Sorry if these files are not well organized, or if I am missing out something that I should have included.
Running Windows 10, QCad/Cam version 3.25.2.4
[Solved] N line number increment
- Test Post.dxf
- (109.35 KiB) Downloaded 396 times
- PT4.js
- (826 Bytes) Downloaded 374 times
- GCode2AxisPT.js
- (10.81 KiB) Downloaded 383 times
- Eventnumber screenshot.jpg (30.66 KiB) Viewed 5597 times
- Thisrapidmove screenshot.jpg (43.39 KiB) Viewed 5597 times
- Eventnumber does not increment.jpg (59.1 KiB) Viewed 5597 times
Re: N line number increment
You'd have to detect when [E] gets written and increment accordingly:
This is overly complicated and we will add a function to detect variable usage more easily. This will work with QCAD/CAM >= 3.25.2.11:
GCode2AxisPT.prototype.writeBlockFromString = function(blockStrings) {
if (isNull(blockStrings)) {
return;
if (isString(blockStrings)) {
blockStrings = [ blockStrings ];
// detect usage of [E]
var incE = false;
for (var i=0; i<blockStrings.length; i++) {
// blockString
// e.g. "[N] G01 [X] [Y]"
var blockString = blockStrings[i];
if (blockString.contains("[E]")) {
// a block string contains variable [E], increment after writing
incE = true;
// write block strings:
CamExporterV2.prototype.writeBlockFromString.call(this, blockStrings);
if (incE) {
this.eventNumber+=this.eventNumberIncrement;
GCode2AxisPT.prototype.variableUsed = function(id, value) {
if (id==="E") {
Re: [Solved] N line number increment
Wow Andrew!
I have no idea how you did that. it works perfect, thanks!
I could have never figured that out.
