Save each toolpath to a seperate gcode file?
slc
Post by slc » Mon Jan 11, 2021 7:40 pm
HI, new user here, is there a simple process to save one toolpath to its own gcode file so each toolpath can be in a seperate file.
I managed to do this somehow but it was clunky and will surely result in an error sooner or later.
Re: Save each toolpath to a seperate gcode file?
Post by andrew » Mon Jan 11, 2021 8:51 pm
In the toolpath widget, where all toolpaths are listed, you can hide individual toolpaths using the eye icon. Hidden toolpaths are not exported. Here, only toolpath "Profile 1" will be exported:
Screenshot 2021-01-11 at 20.50.11.png (33.32 KiB) Viewed 5599 times
slc
Post by slc » Mon Jan 11, 2021 10:27 pm
Many thanks, that must be what I did, but forgot to change the file name first. An easy way to do this with a right click on the toolpath would be good
