[solved]HELP 3D CAM
Bazzo54
[solved]HELP 3D CAM
Post by Bazzo54 » Sat Jan 09, 2021 7:50 pm
Good evening to all
I am at the first experiences with this QCADCAM program, can you draw 3D and then have it executed as a transfer on CAM?
Re: HELP 3D CAM
Post by Husky » Sun Jan 10, 2021 7:57 am
... can you draw 3D and then have it executed as a transfer on CAM?
Yes and no.
3d - no. QCAD is a 2D CAD program.
Transfer to CAM - yes. QCAD will generate a g-code which can be used for CAM.
Bazzo54
Re: [solved]HELP 3D CAM
Post by Bazzo54 » Sun Jan 10, 2021 9:08 am
Thanks for the Husky answer
