See "R Method Example 2"
http://www.manufacturinget.org/2011/12/ ... 2-and-g03/
Is there any way to make that work, perhaps with a different variable or a modifier on RADIUS?
this.firstArcCWMove = "[N] G2 [X] [Y] R[RADIUS] [F]";
this.arcCWMove = "[N] G2 [X] [Y] R[RADIUS] [F]";
this.firstArcCCWMove = "[N] G3 [X] [Y] R[RADIUS] [F]";
this.arcCCWMove = "[N] G3 [X] [Y] R[RADIUS] [F]";
And just in case anyone else out there has a TinyG with the same problem, the TinyG support for negative radii had a bug that I had to fix first.
