Hi All
Just wondering if I'm doing something wrong here, I put 100 in nesting qty and it only fills part of the sheet...
I've just recently moved across to linux mint 20
Cheers
John
Version:
3.25.2.0 (3.25.2)
Internet:
QCAD.org
Build Date:
Sep 4 2020
Revision:
4a61501
Qt Version:
4.8.4
Architecture:
x86_64
Compiler:
gcc 4.4.3
Nesting Problem [ Solved in Snapshot 3.25.2.4.]
- Premier Member
- Untitled.png (183.09 KiB) Viewed 6697 times
Re: Nesting Problem
Thanks. I can reproduce this (under Linux only).
Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2135
Bug report at:
Re: Nesting Problem
Snapshot 3.25.2.4 with a fix is now available.
- Premier Member
Re: Nesting Problem [ Solved in Snapshot 3.25.2.4.]
Thanks Andrew
