SVG Toolpath Export for Glowforge
figbash
Post by figbash » Tue Oct 13, 2020 1:57 am
Hi, I'm trying to decide if I should buy QCAD/CAM or stick with the Pro version. I use a Glowforge laser cutter which uses vector SVGs rather than G-Code, but I would very much like to be able to use the toolpaths to compensate for kerf when I cut the same file on different materials with different kerfs.
Is it possible to output SVGs with the kerf compensation applied from QCAD/CAM, or is G-Code the only option? I tried the demo and couldn't find a way to do it.
Re: SVG Toolpath Export for Glowforge
Post by andrew » Tue Oct 13, 2020 10:28 am
To compensate for kerf in SVG output / for Laser cutting, I'd typically use the Modify > Offset tool to create offset paths on a separate layer, then export that layer to SVG.
Toolpaths would also work, but might be a bit overkill as you usually wouldn't work with lead in / lead out, etc.
