Hi
My cnc machine have problem with arc greater than 180.
I get Autocad file that come in Arc
How I divide the arc that is not more than 180 degrees or is there some that when exporting the code the arc divide greater than 180.
Versions
QCAD version: 3.24.3.0
Date: Mar 17 2020
Qt version: 5.13.0
Compiler version: MSVC++ 14.0 (2015)
Build Date: Mar 17 2020
Revision: a3bef72c136d511dedc5c302e12acd72ff6cc243
[solved] ARC >180
Re: ARC >180
There's a post processor option you can use in the constructor of your post processor to split up arcs at 0, 90, 180 and 270 degrees:
this.splitArcsAtQuadrantLines = true;
