starting qcad using optirun (Linux Mint 19)
Tycho-X
Post by Tycho-X » Fri Aug 21, 2020 7:53 am
i need qcad to run under "optirun" command (Linux Mint 19 with "BumbleBee") so it uses my NVIDIA GFX card instead of the built-in, slow INTEL GFX card. I tried to start qcad like this but without success:
export QT_AUTO_SCREEN_SCALE_FACTOR=1 LD_LIBRARY_PATH=/home/user/opt/qcadcam-3.25.0-pro-linux-qt5.14-x86_64/
optirun ./qcad-bin
Result is
CAD version  3.25.0
14:52:37: Info:    Could not load the Qt platform plugin "xcb" in "" even though it was found.
Fatal:    This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
FreeCAD and LibreCAD are working without problems with "optirun".
cheers....
To CNC Cut what no one has cut before
Re: starting qcad using optirun (Linux Mint 19)
Post by andrew » Mon Aug 24, 2020 10:14 am
The most likely culprit is the OpenGL plugin used for the 3D simulation. You can remove the file plugins/libqcadgles3d.so to remove this OpenGL dependency from QCAD.
You could also try to remove the Qt libraries from your QCAD installation directory, so your system libraries are used instead.
petevick
Post by petevick » Mon Aug 24, 2020 11:19 am
.....You could also try to remove the Qt libraries from your QCAD installation directory, so your system libraries are used instead.
Andrew, which files exactly are they ?
Pete Vickerstaff
Post by andrew » Tue Aug 25, 2020 8:30 am
libQt*
libicu*
plugins/imageformats
plugins/printsupport
plugins/sqldrivers
plugins/xcbglintegrations
platforms/*
platforminputcontexts/*
petevick
Post by petevick » Tue Aug 25, 2020 9:37 am
libQt*
libicu*
plugins/sqldrivers
platforms/*
thanks for that Andrew, unfortunately Qcad will not fire up after removing those files
Pete Vickerstaff
Post by andrew » Tue Aug 25, 2020 10:01 am
You'd have to have Qt 5 installed (exact same version as the one that came with your QCAD package). This is certainly not the recommended way to run QCAD. If it works with the Qt that came with QCAD, I wouldn't recommend to go that route.
petevick
Post by petevick » Tue Aug 25, 2020 10:05 am
I hear what you're saying Andrew, thanks
Pete Vickerstaff
