ERI Post Processor
Jeff66
ERI Post Processor
Post by Jeff66 » Fri Jul 03, 2020 8:14 am
Hi everyone
I'm new with QCAD/CAM. I'm using an ERI NC (Kolly Genève) made for turning on a small Aciera F12 mill. I can manage two axis and it's enough for now. But since the command is made for turning, I have to calculate all the tool path when I want to mill a pocket for example, and this is a bit fastidious.
I'd like to write a specific ERI Postprocessor but before starting, I wonder if it exist allready one or if anyone could help.
FYI, the manual of the ERI command I'm using
http://www.kolly.ch/wp-content/uploads/ ... nglish.pdf
Many thanks in advance for your help !
Jeff
