Menus not working in fullscreen mode ?
Hello all and a very good day to you.
Name here is Joe, new user to QCAD so be gentle.
Question please ?
QCAD/CAM Version: 3.24.3.0 (3.24.3) 64bit
OS Windows 8.1 64bit - fully up to date.
When entering full screen mode - either by using F11 (standard Windows shortcut) - or typing fullscreen in command box in QCAD, the menus are there, but do not function at all. No drop down lists.
Please advise ?
Joe
Question please ?
Please advise ?
Joe
- menu issue QCAD_CAM.jpg (143.45 KiB) Viewed 13346 times
Re: Menus not working in fullscreen mode ?
yes - I can confirm that and filled a bug report for you. Thanks for reporting this.
https://www.qcad.org/bugtracker/index.p ... &sort=desc
Just as info.......Using Windows 10 Pro Version 1909 64bit with Qcad Pro version 3.24.3.0 works ok.
Topic moved to QCAD/CAM
Unfortunately, I cannot reproduce with either QCAD Professional or QCAD/CAM on Windows 10, 64bit.
Ok, I see we have to make it more interesting for you.
QCAD Pro works fine. The issue is with QCAD/CAM.
To show you what is going on I recorded a screen video. During the recording the issue was easy to reproduce. F11 = Menu not working!
Then I checked the recording - every pull down was visible and assumedly working ...
What means ..... it looks like the drop down list doesn't opens on top of the application.
Here my proof that I can't proof it ....
Sounds like a Qt issue, possibly related to OpenGL / Windows Drivers, etc.
One possible solution might be to remove the OpenGL plugin:
plugins/qcadgles3d.dll
This will also remove the 3D simulation widget but otherwise does not affect QCAD/CAM.
Hello guys and thank you for the help with this.
I love Husky's 'proof that he can't prove it' lol I laughed out loud at that.
I can confirm that, with the appropriate DLL renamed the menus now appear.
Hopefully the issue can be resolved at some point.
Thanks again.
Joe
Thanks again.
Joe
Just out of interest, I tested in on my Win 10 Box - as opposed to the laptop.
Same issue. (win 10 64) . The commonality is they both use the processor integrated Intel graphics.
It doesn't seem to be a windows issue. I would suspect the graphics driver. in relation to QT or OGL ?
I have a couple of RTX cards, a 2080ti and a 2070 super that are going in the flightsim rigs. I can test on them when I get around to assembling them.
It may be an issue with Intel's drivers. They are both 4000 series integrated gpus. . the laptop is the HD4000 series GPU and the Win 10 box is the HD4600 GPU.
there was a release of a 4000 series driver update a few days ago - mainly for bug fixes it appear. I just installed that and no difference.
Hope that helps fault finding.
Joe
Joe
Additional observation:
I run a few programs on my Win10/64 which are displaying smaller windows on top of every other opened program. That is by design and what ever I do they have to stay on top. Even F11 used at any other program will not change that.
Except this particular QCAD/CAM version! It will force ALL not QCAD/CAM related "on top windows" to disappear in the background. Hope this info helps a bit ...
Hi Husky
Out of interest, what GPU are you using please ?
Joe.
Joe.
Hi Andrew and Husky.
More info that may help.
QCAD/CAM tested on Intel HD4000, Intel HD4600 and Intel® HD Graphics for Intel Atom® Processor Z3700 Series. The problem occurs on all.
Here is - what I hope - is an informative OpenGL diagnostic report using the excellent GPU_Caps_Viewer_1.44.3.1
Joe
Joe
Nothing fancy ...
Intel HD Graphics 520
Thanks,
Would appear to be related to intel integrated gpu. Hopefully the file attached regarding the OGLdata dump (perhaps a data 'dump' doesn't quite have the same meaning in your neck of the wood huh ?) haha.
