I am getting strange gcodes with cam export.
It seems I get a good export from cam legacy export but not from the main cam export.
Is this something I am missing in setup? where should I start to look?
Version:
3.24.2.0 (3.24.2)
Internet:
QCAD.org
Build Date:
Jan 10 2020
Revision:
f05abb0
Qt Version:
5.8.0
Architecture:
x86_64
Compiler:
gcc 4.8.1
QCAD/CAM is an application for computer-aided design (CAD).
QCAD/CAM is based on QCAD, a free (open source) software.
Plugins and script add-ons are subject to their respective license (see "Plugins" tab).
All brand or product names are trademarks or registered trademarks of their respective holders.
© 2011-2019 RibbonSoft, GmbH.
Portions of this software © 2008-2019 The Qt Company Ltd.
Qt ships with QCAD under the LGPL Open Source license which confers various rights to you as the user, including the right to recompile the Qt libraries for your platform. To do that follow the documentation shown on the Qt website.
The program is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
strange gcode export
- 3-Vonney's Valley15.nc
- (8 Bytes) Downloaded 335 times
- 3-Vonney's Valley15-legacy.nc
- (895.62 KiB) Downloaded 317 times
- Vonney's Valley15.dxf
- (116.87 KiB) Downloaded 329 times
Re: strange gcode export
As always, please attach the DXF file with the tools, toolpaths, etc.
There are no toolpaths defined in this drawing for the chosen post processor "GCode Offset [mm]". This will only export a header and footer.
To learn how to define toolpaths, please refer to our QCAD/CAM tutorial at:
https://qcad.org/en/tutorial-qcad-cam
P.S.: I've also noticed that there are five text entities on top of each other which might not be intended.
