Contour orientation not defined?
curnowdj
Post by curnowdj » Fri Mar 06, 2020 5:32 am
G'Day Gang,
Not having a lot of success exporting gcodes. I am getting a error saying "Contour orientation not defined" I have not been able to find a solution from internet searches. My question is where and how do I define the contour orientation?
TIA
Re: Contour orientation not defined?
Post by andrew » Fri Mar 06, 2020 8:39 am
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD/CAM you are using (see Help > About or QCADCAM > About QCAD/CAM or indicate the name of the file you have downloaded and installed)
- Attach original drawing files (DXF, DWG, ...)
curnowdj
Post by curnowdj » Fri Mar 06, 2020 9:18 am
Qcad/qcadcam-3.24.2-pro-linux-x86_64.run on Ubuntu 18.04
curnowdj
Post by curnowdj » Fri Mar 06, 2020 9:19 am
Version:
3.24.2.0 (3.24.2)
Internet:
QCAD.org
Build Date:
Jan 10 2020
Revision:
f05abb0
Qt Version:
5.8.0
Architecture:
x86_64
Compiler:
gcc 4.8.1
Post by andrew » Fri Mar 06, 2020 9:44 am
Please do attach or e-mail the DXF file with the contour(s) / toolpath(s) as this is very likely the key to what causes the problem.
curnowdj
Post by curnowdj » Fri Mar 06, 2020 12:16 pm
G'Day Andrew,
Not sure what I did but the issue has disappeared. If it comes back I will post the file.
Post by andrew » Fri Mar 06, 2020 1:01 pm
OK. It would usually indicate a contour that is not (or not precisely enough) closed.
