Drill Postprocessor
Claudiosp
Drill Postprocessor
Post by Claudiosp » Tue Feb 11, 2020 4:36 pm
Hi
In my post for Biesse I have this
// point moves for drilling:
this.firstPointMoveZ = "[N] [X] [Y] [T] VF=[FP] PRF=[Z-] L=G99";
this.pointMoveZ = []
Output this
N30 X43.5345 Y37.4059 T2 VF=1 PRF=10 L=G99
N40 T2 VF=1 PRF=0 L=G99
How remove N40 T2 VF=1 PRF=0 L=G99
Re: Drill Postprocessor
Post by andrew » Tue Feb 25, 2020 1:30 pm
I don't have enough context, but that could be the Z move to move up after drilling. To disable:
MyPostProcessor.prototype.writeLinearMoveZ = function() {
    if (this.zStartPosition < this.zPosition) {
        // disable all Z up moves:
        return;
    else {
        this.writeBlock("linearMoveZ");
Be sure to properly check / verify that this is exactly what you want as disabling all Z up moves seems suspicious to say the least.
Claudiosp
Post by Claudiosp » Wed Feb 26, 2020 1:27 pm
HELP ME
this.firstPointMoveZ = "[N] [X] [Y-] [T] VF=[FP] PRF=[Z-] L=G99";
// command to execute after writing file:
this.alwaysWriteG1 = true;
BIESSE.prototype.writeLinearMoveZ = function() {
return;
else {
// Derive our class from class GCodeBase:
BIESSE.prototype = new GCodeBase();
// Display name shown in user interface:
BIESSE.displayName = "BIESSE";
Post by andrew » Wed Feb 26, 2020 1:31 pm
BIESSE.prototype.writeLinearMoveZ = function() { .... }
has to be after
Otherwise it has no effect, since prototype is overwritten immediately and writeLinearMoveZ deleted.
Claudiosp
Post by Claudiosp » Wed Feb 26, 2020 3:32 pm
NOT WORK
// linear Z moves:
this.firstLinearMoveZ = [];
this.linearMoveZ = [];
// circular moves:
this.firstArcCWMove = "[N] G5 [X] [Y-] [RADIUS-]";
this.arcCWMove = "[N] G5 [X] [Y-] [RADIUS-]";
this.firstArcCCWMove = "[N] G4 [X] [Y-] [RADIUS-]";
this.arcCCWMove = "[N] G4 [X] [Y-] [RADIUS-]";
// tool compensation on:
this.linearMoveCompensationLeft = [
"[N] G42 G69 [X] [Y-] G1 ",
this.linearMoveCompensationRight = [
"[N] G41 G69 [X] [Y-] G1 ",
// tool compensation off:
this.linearMoveCompensationOff = [
"[N] G40 [X] [Y-] G1 ",
"[N] L=PSU",
// linear lead in / out:
// these default to this.lineadMove:
this.linearLeadIn = [];
this.linearLeadOut = [];
this.firstPointMoveZ = ["[N] [X] [Y-] [T] VF=[FP] PRF=[Z-] L=G99",
return;
else {
Post by andrew » Wed Feb 26, 2020 4:28 pm
Please post your entire post processor file.
Claudiosp
Post by Claudiosp » Wed Feb 26, 2020 4:33 pm
* This file is part of the QCAD/CAM software.
* Do NOT edit this file. Your changes will be lost when the software
* is updated or reinstalled.
* For details, please refer to the file README.txt in this directory.
// Include GCodeBase.js which contains the class 'GCodeBase', used as base for our own configuration:
include("GCodeBase.js");
// Constructor of our class:
function BIESSE(documentInterface, newDocumentInterface) {
// Call constructor of base class:
GCodeBase.call(this, documentInterface, newDocumentInterface);
this.registerVariable("feedRate", "F", true, "", 0);
this.registerVariable("plungeRate", "FP", true, "", 0);
this.registerVariable("zClearancePass", "ZUP", true, "", "DEFAULT", "DEFAULT");
this.registerVariable("zStart", "Z_START", true, "", "DEFAULT", "DEFAULT");
this.registerVariable("zEnd", "Z_END", true, "", "DEFAULT", "DEFAULT");
this.registerVariable("zCuttingDepth", "ZD", true, "", "DEFAULT", "DEFAULT");
this.registerVariable("tool", "T", true, "", 0);
this.registerVariable("arcRadius", "RADIUS", true, "R", "DEFAULT", "DEFAULT");
this.registerVariable("zPosition", "Z", false, "", "DEFAULT", "DEFAULT");
this.registerVariable("zStartPosition", "Z1", true, "", "DEFAULT", "DEFAULT");
this.fileExtensions = [ "",];
this.decimals = 4;
this.unit = RS.Millimeter;
this.header = [
"[COMMENTO]",
"[CENTRO01]",
"PARAMETRI=000000208",
"UTENSILI=000000303",
"LABELF=000003772",
"LABELC=000003759",
"FORATURA=000003726",
"CONTORNATURA=000000318",
"TABELLEFORI=000003741",
"CONFASSIST=000003785",
"ATTREZZAGGIO=000003802",
"[PARAMETRI01]",
"[N] G71 HC=1 LY=[Y_MIN-] LZ=[Z_MAX] FIL=0 BLO=0 ACC=0 RUO=2 PRS=1 PRL=1 Z=PRK KA=0 LX=[X_MAX] ",
"[UTENSILI01]",
"[CONTORNATURA01]",
this.footer = [
"[N] G0 L=POFF",
this.toolHeader = [
"[N] PAN=1 ST1=\"[T]\" L=PCUA",
"[N] XO0 YO0",
this.toolFooter = [];
// header / footer before / after single Z pass:
this.singleZPassHeader = [];
this.singleZPassFooter = [];
// header / footer before / after first pass of mutliple or single Z pass(es):
this.zPassFirstHeader = [
"[N] [XF] [YF-] Z=PRK PRF=[Z1-] F=[F] VF=[FP] G40 TP=1 L=PON TRZ=0 M55 ",
this.zPassFirstFooter = [];
// header / footer before / after each pass of mutliple Z passes:
this.zPassHeader = [
"[N] [XF] [YF-] Z=PRK PRF=[Z-] F=[F] VF=[FP] G40 TP=1 L=PON TRZ=0 M55 ",
this.zPassFooter = [];
// rapid moves:
this.rapidMove = [];
this.rapidMoveZ = [];
// linear moves:
this.firstLinearMove = "[N] G1 [X] [Y-]";
this.linearMove = "[N] G1 [X] [Y-]";
// linear Z moves:
// circular moves:
"[N] L=PSU",
return;
else {
Post by andrew » Wed Feb 26, 2020 4:56 pm
I've attached the adjusted post processor.
BIESSE.js
(4.36 KiB) Downloaded 503 times
Claudiosp
Post by Claudiosp » Wed Feb 26, 2020 5:21 pm
firstPointMoveZ
N30 XO0 YO0
N40 X50 Y50 T1 VF=0 PRF=10 L=G99
N50 X83.7894 Y21.8884 T1 VF=0 PRF= L=G99
N60 X164.1622 Y32.5882 T1 VF=0 PRF= L=G99
N70 G0 L=POFF
IN LINES
N40 PRF= \\ IS CUT DEPTH
N50 PRF= \\ IS CUT DEPTH
I NEED OUT THIS
N40 PRF=10 \\IS CUT DEPTH
N50 PRF=10 \\ IS CUT DEPTH
Claudiosp
Post by Claudiosp » Wed Feb 26, 2020 5:59 pm
this.registerVariable("zPosition", "Z", true, "", "DEFAULT", "DEFAULT");
true
FIX
Claudiosp
Post by Claudiosp » Wed Feb 26, 2020 7:14 pm
WHY LEAD IN NOT DO ZERO DEGREES
IN EXTENSION TOLL LEAD IN ON MATERIAL
Post by andrew » Thu Feb 27, 2020 8:29 pm
Please post new, unrelated questions to a new thread. Please avoid writing all in capital letters.
Thanks.
