versions 3.24.0 and 3.24.2 core dumps on quit, I’m not have this problem under 3.23.0. The core dump only happens if I open a file or save a file and then quit the program.
It is good to draw and create drawings and quit without any core dump as long as I not save my work, if I do, it core dumps when I quit program! I don’t have this behavior in the 3.23.0 version.
This is the error message I got. same for the 3.24.2 version.
I have test on 3 different computers all on Kubuntu 18.04 latest update. I’m using Qcad from tar archive qcadcam-3.24.0-pro-linux-x86_64.QCAD version 3.24.0
Warning: RPropertyTypeId::generateId: property already initialized: 7RObject : "" : "Invisible"
09:52:54: Debug: RGLES3DPlugin::initScriptExtensions
09:52:55: Debug: RGraphicsViewGLES3D::initializeGL
09:52:56: Debug: RGLES3DPlugin::initScriptExtensions
09:53:03: Debug: calling odInitialize
09:53:04: Debug: dropped global XDATA (no res buf): "ViewportCenter"
09:53:04: Debug: RGLES3DPlugin::initScriptExtensions
09:53:08: Debug: done
pure virtual method called
terminate called without an active exception
./qcad: line 9: 4735 Aborted (core dumped) LD_LIBRARY_PATH="$DIR" "$binary" "$@"
QCAD has unexpectedly quit.
Please use the offscreen platform plugin for headless systems
(without a running X11 server):
./qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
./qcad -style plastique
Can anyone confirm if this is related to my computers, settings, Kubuntu OS or is this actually a program fault.
/Stema
