Import Gerber files
malennachzahlen
Import Gerber files
Post by malennachzahlen » Mon Jan 20, 2020 2:39 pm
Hello Community!
I've got a bunch of GERBER-files from our costumer to create the panel for the pcb. Usually I'm using IDF but in this case it's not possible.
A little research showed the well known and used QCAD can handle Gerber so I gave it a try befor buying. The result
is not as expected. :shock:
All the radii of the outline and millings are lost. What went wrong and how can I fix this behavior?
I'm using a fresh downloaded and installed 30 days trail version of QCAD/CAM 3.24.2.0 running under Windows7.
Thanks for your help
malennachzahlen
BoardOutline.gbx
(916 Bytes) Downloaded 389 times
Re: Import Gerber files
Post by CVH » Mon Jan 20, 2020 3:56 pm
Versuchte Datei:
Import oder Öffnen fehlgeschlagen:
>Fehler beim Importieren der Datei C: /Users/Admin/Desktop/BoardOutline.gbx
>Datei 'C: /Users/Admin/Desktop/BoardOutline.gbx' kann nicht geöffnet werden. Kein passender Importeur gefunden. Bitte überprüfen Sie das Dateiformat und die Dateierweiterung.
EDIT: Art von G-Code
Grüße
Tried file:
Import or Open fail:
>Error while importing file C:/Users/Admin/Desktop/BoardOutline.gbx
>Cannot open file 'C:/Users/Admin/Desktop/BoardOutline.gbx'. No suitable Importer found. Please check file format and extension.
EDIT: kind of G-code
Regards
Post by andrew » Tue Jan 21, 2020 12:02 pm
I can confirm that in single quadrant mode (G74), arcs are not supported at this point. This might be added in a future release.
Post by CVH » Tue Jan 21, 2020 12:49 pm
I see now,
It is a CAM file format ... That Pro's can not load. Why?
It is not listed in features list.
Tought I clicked on a link to the complete list of features:
https://qcad.org/en/qcad-documentation/qcad-features
