QCAM for Flow waterjet and TruTops Laser
BlackLight
Post by BlackLight » Fri Dec 06, 2019 2:58 am
Good day!
I am new here and thinking of purchasing this QCAD/QCAM software, but first I need to know if it can create programs for these 2 machines. Can it also generate .lst files similar to the ones we are currently loading into our machines.
Any help or assistance will be greatly appreciated.
Thank you
Re: QCAM for Flow waterjet and TruTops Laser
Post by andrew » Fri Dec 06, 2019 2:32 pm
QCAD/CAM postprocessors can be adjusted in any desirable way using ECMAScript (JavaScript). If these controllers accept a type of G-Code, creating a post processor should be relatively easy. If not, it would require more effort. If you can post sample files, I can tell you more.
Return to “QCAD/CAM”
