Cutting order does not work - Legacy cam script
qharley
Post by qharley » Sat Aug 31, 2019 11:44 am
I misposted this on the 17th of August in the QCAD-Pro forum.
https://qcad.org/rsforum/viewtopic.php? ... 449#p24449
I have a problem since upgrading to QCAD-CAM 2.23
The problem is that the cam does not generate the gcode in the correct order, effectively ignoring "Cut inner first" causing havoc on my laser cutter.
I am currently working around this by running QCAD-CAM 2.21 to generate the gcode of me, but this is not very convenient.
Please help.
qharley
Re: Cutting order does not work - Legacy cam script
Post by qharley » Sat Aug 31, 2019 11:47 am
The versions are actually 3.23 and 3.21
in other words, the latest one is causing the trouble.
Post by andrew » Mon Sep 02, 2019 8:00 am
Please post your drawing file and post processor script, so we can help you efficiently, thanks.
qharley
Post by qharley » Fri Sep 20, 2019 4:33 pm
Here is a link to the relevant files.
This is a very simple example that demonstrates the problem efficiently.
I also included the two gcode files created by the different versions.
The actual scripts, and the settings were identical for each run.
I included the log files for extra information
https://www.dropbox.com/sh/3bhosm6qrd9h ... g83ga?dl=0
qharley
Post by qharley » Sat Sep 21, 2019 1:54 pm
Let me know if you have any difficulty reading the files due to permissions etc.
qharley
Post by qharley » Fri Sep 27, 2019 1:19 pm
Checked the latest snapshot
Version:
3.23.0.2 (3.23.0.2)
The problem remains.
