Z Axis Feed Rate
mooseuk
Z Axis Feed Rate
Post by mooseuk » Sat Sep 08, 2018 11:55 pm
Hi all,
Where do you set the feed rate for the Z Axis ?
My generated G code shows it as zero and I have to edit it to show a feed rate.
Ta
Re: Z Axis Feed Rate
Post by andrew » Mon Sep 10, 2018 9:02 am
The Z feedrate is labeled as "plunge rate".
The default plunge rate for a tool can be defined in the dialog when adding a tool:
Screen Shot 2018-09-10 at 08.59.15.png (50.33 KiB) Viewed 5927 times
When creating a profile toolpath, the plunge rate can be adjusted for that particular profile if desired:
Screen Shot 2018-09-10 at 08.59.26.png (122.82 KiB) Viewed 5927 times
mooseuk
Post by mooseuk » Mon Sep 10, 2018 9:12 am
Thanks Andrew, I am new to this and thought those fields were for setting the feed increment !
Really must read the manual before diving in.
All sorted now
