Rough Cut/Finish Cut
Dreamaker
Post by Dreamaker » Sat Sep 09, 2017 11:42 pm
I want to make a part for my bicycle, I will be using my CNC 4 axis router and will be cutting 25.4mm polycarbonate a 2D object. There will be one circular pocket and a outside profile. Now being reasonable size, I would not use a 2mm cutter, I would be using a 6.3mm/.25” cutter to do the outside profile. My problem is, in the profile I would like to do some tight inside corners like 1mm radius. So my question is: Is it possible to do a rough cut, than a finish cut? Or do I need to make two separate Gcode programs, one for rough cut and the other finish cut for the profile?
Clive
Moderator
Re: Rough Cut/Finish Cut
Post by Clive » Sun Sep 10, 2017 2:29 pm
You can add a new tool, so in my example here I have T1 (6.35mm end mill) used for the round pocket hole and the first 'rough' profile cut and then T2 (1mm end mill) to fine tune the outside to get into the tight 1mm corners!
All this is within one g-code program.
Tool change for clean-up around perimeter.jpg (20.48 KiB) Viewed 5674 times
Add tool.jpg (63.34 KiB) Viewed 5675 times
Tool change for clean-up around perimeter-gif.gif (17.36 MiB) Viewed 5675 times
