Horizontal Groove/slot
I don't know if anyone have messed around with putting horizontal grooves, slots in item, using Qcad/Cam and Mach3. Really have no need for it at this point, I just wanted to know if I could do it. At first I had issues with using two different tools, because of tool change issue. I tried doing it using as two separate projects, which worked and didn't work. So after getting my manual tool change issue setup and working, and running it as one project, it seemed to work well. My machine is a 300X400 4 axis CNC router, with a 800 watt water cooled spindle. The groove tool I used is a Dremel #199 rotary saw like tool. I have seen larger diameter, but haven't been able to locate any. We had some where I use to work, so I know they exist. I found similar cutters by different name, but are too large for my system, (Woodruff key cutter, Key-way cutter and so in). I am still experimenting and this is just one step. Here are some pics of piece and tool used.
- P1010018.JPG (57.87 KiB) Viewed 8979 times
- P1010016.JPG (62.13 KiB) Viewed 8979 times
- P1010015.JPG (52.4 KiB) Viewed 8979 times
- P1010014.JPG (52.97 KiB) Viewed 8979 times
Re: Horizontal Groove/slot
Interesting.
Just curios - was a 4. axis involved or only 3? If only 3 you used an extra circle in the drawing for the grove tool path?
I used the 3 axis! I used a Dremel tool bit, shown in the pic. Yes I did an extra circle for the groove.
Thanks for the info. I played with this idea (theoretical!) and I think it would also work without an extra circle. I used the Lead in Typ / Half Circle.
I would like to find more cutters in that style, maybe a little larger diameter with a 1/8" to 1/4" shank other than the Dremel tool. I know they are out there, I just can't find them. We had some at work, don't know what they used them for or where they got them. I am retired, so I called one of the people I worked with, and he could not find them. I found some similar, but with large shanks, by using different names of its purpose. Haven't had a real need at this point for it, but I originally did it to see if it was capable of doing it.
