Other types of toolpaths?
Clive
Moderator
Post by Clive » Thu Dec 29, 2016 1:28 pm
In the tutorial you've outlined in red that 'In future releases, other types of toolpaths will be available, for example for pockets'
are you able to briefly expalin what they may be and any additional info about this please?
Clive
Moderator
Re: Other types of toolpaths?
Post by Clive » Thu Dec 29, 2016 2:59 pm
Right I'm going to answer my own questions here based on what I know about manual free hand held and fixed routing - it has to be the same principles here!
Okay my assumption of a profile cut tool path has to be a complete cut through cut leaving the shape and a pocket tool path must be about any shape where the material is partly taken out by passes and not all the way through.
Correct?
Post by andrew » Thu Dec 29, 2016 3:12 pm
Yes, correct. A pocket toolpath would clear out all material inside a given contour, but not all the way through.
Clive
Moderator
Post by Clive » Thu Dec 29, 2016 3:21 pm
Thanks and you say you will add this soon?
Post by andrew » Thu Dec 29, 2016 3:28 pm
Clive wrote:Thanks and you say you will add this soon?
It's certainly one of the next things on my list for QCAD/CAM. No promises though.
The basic logic needed for this is already there though (polyline offset tool):
Screen Shot 2016-12-29 at 15.27.12.png (123.22 KiB) Viewed 7175 times
Clive
Moderator
Post by Clive » Thu Dec 29, 2016 5:12 pm
Okay thanks Andrew.
