Hey All,
I've created a custom CAM export configuration, and now I'd like to be able to go the other direction (import the generated g-code as geometry). Should this be possible with the built-in CAM import feature? Or do I need to edit a script or the source code? When I try to use the cam import tool with my g-code, I don't get any error, the layers show up in the layer editor, but no geometry appears in the graphics window.
Thanks,
Pete
OS: Windows 7 & 10
QCAD version: 3.15, CAM trial
CAM import for alternative CAM export configurations
- Newbie Member
Re: CAM import for alternative CAM export configurations
No. The CAM importer only reads plain, simple G-Code (G0 for rapid moves, G1 for linear moves, G2 & G3 for circular arcs).Peter York wrote:I've created a custom CAM export configuration, and now I'd like to be able to go the other direction (import the generated g-code as geometry). Should this be possible with the built-in CAM import feature?
Depending on how different your output is from this, you'd likely have to create an entirely new importer for that format.
- Newbie Member
Thanks, Andrew-- turns out if I rename the axes in my gcode from GX/GY/Z to X/Y/Z the built-in importer works just fine (which makes sense, I think). Is there a way to edit the CAM importer to look for GX/GY instead of X/Y? Do I need to buy the non-trial version of QCAM to access these files?
Thanks a lot!
Pete
Thanks a lot!
Pete
QCAD/CAM 3.15.2 comes with some configuration options to configure the regular expressions used for parsing G, X, Y, I and J values in G-Code. The default expression is also more relaxed than in previous versions, so this might just work out of the box for you:
http://www.qcad.org/en/qcad-downloads-trial
- Newbie Member
Thanks, Andrew! Worked great out-of-the-box for me!
Cheers,
Pete
Cheers,
Pete
