Get Layer Option broken 3.13.1
srl
Post by srl » Sat Apr 02, 2016 7:21 am
Hi Andrew
I was just having a look at the latest GCode.js.
To get it working again I changed line 161 to this
 // return layer.getCustomProperty("QCAD", name, def);
return layer.getCustomProperty("QCADCAM", "Cam/"+ name, def);
Unlike the CAM Global options the layer options are lost when the file is reloaded , Its a turn off for those first looking at CAM and the reason I went with the layer names options.
Could this be fixed?
Your lead in code looks interesting, any clues on how to use it or is it work in progress? I noticed the in and out from centre no longer works.
All good stuff
srl
Re: Get Layer Option broken 3.13.1
Post by andrew » Tue Apr 12, 2016 9:39 am
This should be fixed in the latest update (3.14). Please note that custom properties have to be stored under title "QCAD" in order to be stored with the DXF/DWG file.
BTW: You might want to enable Edit > Application Preferences > Widgets > Property Editor > Display properties of current block and current layer, so you can view and edit layer properties using the property editor.
