CAM export: IJ relative/absolute value in G02 G03
AMWILL
Post by AMWILL » Fri Mar 21, 2014 12:36 pm
Newbie from Italy.
qcad pro 3.4.6.0 on windows 7 pro.
CAM export writes G02 and G03 strings using the relative I and J.
Is there a way to force CAM export to use absolute i J values ?
my hurco CNC requires that format and I'm stuck.
Re: CAM export: IJ relative/absolute value in G02 G03
Post by andrew » Fri Mar 21, 2014 2:26 pm
Please save the two attached files into the directory "scripts/Cam/CamConfigurations" (overwrite the existing file "GCode.js").
When converting a file to G-code, choose the configuration "GCodeAbsIJ" to generate G-code with absolute I and J coordinates.
GCodeAbsIJ.js
(217 Bytes) Downloaded 571 times
GCode.js
(10.38 KiB) Downloaded 566 times
AMWILL
Post by AMWILL » Fri Mar 21, 2014 5:34 pm
Works perfectly. Thanks a lot Andrew.
