[solved] Nesting issues
pantau
Post by pantau » Mon Feb 05, 2024 8:20 pm
I have upgraded from pro to cam to use the nesting function. However, it does not work as expected. If I set rotations to 4, all parts are nested. However, as soon as I set rotations to 1 as required, only one part is inserted. What am I doing wrong?
Thanks for your support!
GO_7_v6_dacron.dxf
(367.14 KiB) Downloaded 158 times
Re: Nesting issues
Post by andrew » Mon Feb 05, 2024 9:35 pm
Can you please try with the following default preferences:
Weighing of primary alignment (Gewichtung der Primärausrichtung): 2.0
Hull resolution for blocks (Hüllenauflösung für Blöcke): 20
pantau
Re: Nesting issues
Post by pantau » Mon Feb 05, 2024 9:44 pm
Didn't change anything :-(
Re: Nesting issues
Post by andrew » Tue Feb 06, 2024 7:51 am
OK, thanks.
Can you try enabling another default: Place small parts into holes of other parts (Kleinteile in den Aussparungen anderer Teile anordnen)
pantau
Re: Nesting issues
Post by pantau » Tue Feb 06, 2024 11:07 am
For whatever reason, it helped e_surprised
At least on my windows computer, I'll check it under linux tonight.
Thank you very much!
Re: Nesting issues
Post by andrew » Tue Feb 06, 2024 11:10 am
Thanks for your confirmation.
Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2526
This has been fixed for the next release.
Re: [solved] Nesting issues
Post by andrew » Wed Feb 07, 2024 2:54 pm
QCAD/CAM 3.29.4 is now available which should fix this issue.
pantau
Post by pantau » Wed Feb 07, 2024 8:56 pm
nice :-D
