[solved] Nesting issues
I have upgraded from pro to cam to use the nesting function. However, it does not work as expected. If I set rotations to 4, all parts are nested. However, as soon as I set rotations to 1 as required, only one part is inserted. What am I doing wrong?
Thanks for your support!- Attachments
- GO_7_v6_dacron.dxf
- (367.14 KiB) Downloaded 155 times
Re: Nesting issues
Can you please try with the following default preferences:
Weighing of primary alignment (Gewichtung der Primärausrichtung): 2.0
Hull resolution for blocks (Hüllenauflösung für Blöcke): 20
Re: Nesting issues
Didn't change anything
Re: Nesting issues
OK, thanks.
Can you try enabling another default: Place small parts into holes of other parts (Kleinteile in den Aussparungen anderer Teile anordnen)
Re: Nesting issues
For whatever reason, it helped
At least on my windows computer, I'll check it under linux tonight.
Thank you very much!
Re: Nesting issues
Thanks for your confirmation.
Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2526
This has been fixed for the next release.
Bug report at:
Re: [solved] Nesting issues
QCAD/CAM 3.29.4 is now available which should fix this issue.
