Hello from Poland
Krzysztof
Hello from Poland
Post by Krzysztof » Sun Jan 08, 2023 12:41 am
I've been using QCAD since 2020 for hobby purposes at home. I use IronCAD at work. I deal with mechanics and mechanical engineering, but I also use QCAD for construction projects.
Re: Hello from Poland
Post by Husky » Sun Jan 08, 2023 1:07 am
Hello Krzysztof, thanks for introducing yourself and welcome to the QCAD forum.
